It is currently Sun Aug 03, 2025 6:34 pm
 Post subject: Cutting Brace Ends
PostPosted: Tue Nov 06, 2018 6:27 pm
Here’s a little trick I have been using for a long time when cutting brace ends to length while fitting a top or back. I was doing that today and shot a picture.
Protect the blade of an XActo razor saw with binding tape leaving a small cutting area and you can saw almost through the brace without worrying about damaging the top or back. Complete the cut with a blade and pop off the end with a chisel.
You have be a little careful as you can crease spruce with the tape if you really lean into it.
These users thanked the author Terence Kennedy for the post (total 4): Robbie_McD (Mon Nov 12, 2018 8:37 am) • Tim Mullin (Sun Nov 11, 2018 6:50 pm) • Pmaj7 (Wed Nov 07, 2018 1:26 am) • bcombs510 (Tue Nov 06, 2018 6:44 pm)
 Post subject: Re: Cutting Brace Ends
PostPosted: Tue Nov 06, 2018 7:31 pm
Neat.
I've just started using a Hosco brace saw (convex) for my brace ends.
Just cut until I feel the glue, chisel off the nub and then use hot water to remove the glue and any traces of wood remaining
PostPosted: Tue Nov 06, 2018 11:37 pm
Nice Mac Ebony (assume...) there Terrance!
Great tip.
PostPosted: Wed Nov 07, 2018 12:50 am
Thanks Rod. Actually it is some great Brazilian from fellow forum member Hans Brentrup :)
PostPosted: Wed Nov 07, 2018 12:55 am
Wow! Super dark... can't wait to see more of that one...
PostPosted: Wed Nov 07, 2018 6:38 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Does anyone use a veneer saw for this task? I have one, but I have not tried it for this yet (I have only used it for its intended purpose). Veneer saws have thin, convex blades, so I was thinking it would be a good tool for avoiding the collateral damage a flat saw blade can cause.
PostPosted: Wed Nov 07, 2018 7:54 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I have used a veneer saw and it works well. I put a little piece of blue tape on either side of the brace and when the blade hits the tape, the convexity? of the blade means it is through enough. Cheap and available. You can even buy just the blade and screw it through the holes onto a stick:
https://www.amazon.com/Kunz-Veneer-Saw-Replacement-Blade/dp/B0034YUVM6/ref=sr_1_7?ie=UTF8&qid=1541595173&sr=8-7&keywords=veneer+saw
Ed
These users thanked the author Ruby50 for the post: bcombs510 (Tue Nov 13, 2018 3:33 pm)
PostPosted: Wed Nov 07, 2018 10:34 am
Last Name: Parker
City: Charleston
Thanks, Ed. I own two of them; I look forward to devoting one to this task. I always seem to nick the soundboard when using a regular, flat blade razor saw.
PostPosted: Wed Nov 07, 2018 11:16 am
I used to use a veneer saw, but now use an oscillating tool with a half moon blade. I've found a multitude of uses for that tool.
PostPosted: Wed Nov 07, 2018 11:19 am
Last Name: Lee
Country: Wales U.K.
I use one of these which I found recently on eBay. https://www.flinn-garlick-saws.co.uk/ac ... y_Saw.html
It was new and less than half the listed price. I was the only one who bid for it. :D
PostPosted: Sun Nov 11, 2018 5:05 pm
First name: David
Last Name: Wren
State: ON
Zip/Postal Code: M4C 4X5
Nice tip Terence ... thanks for posting
Users browsing this forum: Ken Lewis and 17 guests
